Phraseology problem...
    This came on my CCA news...
    The CCA Talks Chop on Alberta Prime Time
    In case you missed it, CCA director and
    animal care committee chair, Dave
    Solverson, recently appeared on Alberta
    Prime Time to take part in a panel
    discussion examining whether cattle
    should be fed grass or grain; which is
    better for the animal and ultimately the
    health of the consumer. Solverson, also
    an executive of the Alberta Beef
    Producers, was joined in the discussion
    by a grass-fed proponent.
    Solverson landed several key points in
    the discussion. He set the tone
    immediately after being introduced ‘as a
    producer who feeds his cattle grain’ by
    clarifying for the show’s host the
    meaning of grain finishing (ie: that 80
    per cent of the production of that
    animal is grass-based, with an average
    of 100-150 days spent on a high grain
    ration to finish the animal to the
    acceptance of consumers). Other points
    made included that the barley fed to
    cattle in Alberta is from the same
    botanical family as the grasses
    producers already use and the importance
    to the structure of western agriculture
    to have a vibrant feed grains market.
    He noted grain-finishing is the practice
    of the majority of producers, and talked
    about the positive attributes the
    practice imparts on beef and the demand
    for the trim.
    “Alberta built its reputation on grain
    fed beef and it is world recognized as a
    tremendous product,” Solverson told the
    show’s host.
    To watch the piece in full, go to:
    http://www.albertaprimetime.com/Stories.
    aspx?
    pd=1235&FlashVars=Video/PTG_071410.flv.
    My thoughts...
    I for one, did not like the pitting of
    one type of production against another,
    or the fact that CCA would be seen to
    endorse one type of production over
    another. I think grain
    feeding/finishing is fine, and don't
    have issues with the practice, but I
    think the same about grass fed. Each
    type of beef (broad categorically
    speaking) has different attributes that
    can help serve a broader customer base
    than any single type of beef alone. I
    heard Tom Field (executive of NCBA) at
    BIF tell the crowd he supports organic,
    natural, grainfed, grassfed, humanely
    raised, etc. Basically he said he
    supports beef and anything that serves
    any segment of the consumer base and
    grows market share.
    I am not sure that the type of
    discussion above embodies the same
    perspective on our side of the border.
    I like Dave and think it is fine for him
    to appear on Prime Time representing
    himself on this issue or even AB Cattle
    Feeders, but not CCA. I am surprised
    the CCA article did not even mention
    Griebel's position.
    Good old Dave - proving again why we need a refundable checkoff levy. Along with his cronies he uses similar dumb arguments to suggest that the status quo is our only option, the packers are good and that we must be allowed to sell hormone implanted beef to people who don't want to buy it.
    So was he simply lying or is his math not very good? 80% of the production is grass based would indicate on a 1300lb steer only 260lbs of that gain is put on with grain in the feedlot even with only 100-150 days on feed it's more than that.
    As always in Alberta - the facts are negotiable as long as the ideology stands.
      Careful guys, this sounds like the old tried and true "divide and conquer" principle again.
      Personally I think cattle producers, feeders, and everyone else should try and avoid this debate at all costs.
      Instead they should all be working together and telling consumers that there is a beef product out there to suit the preferences of everyone.
      This fact should be one of our biggest strengths, not just another way to divide us. Why does GM make compact cars, trucks, vans, and family sedans? Because not every GM customer wants the same vehicle, yet they may prefer to buy GM.
      To be able to provide whatever type and style of beef that a customer could possibly want is an amazing selling point. Unless you personally know a small farmer somewhere, you sure can't get that kind of variety in poultry or pork.
      So we don't need to fall into this trap. We need to be smarter than that.
        Right on Kato. In that spirit I will once again take on good ol' GF. I don't know why he came to Alberta where, in his mind he lives among the stupid. However people who live in glass houses had best avoid stones, something he hasn't learned. I would like to support the 80/20 forage/grain ratio for beef production that Dave Solverson stated. What simple farmer missed is that the 1300 lb steer had a 1300 lb mother that ate 26 lbs of forage every day for a year to produce the 550 lb weaned calf. From 550 to 850 he likely consumed about 3000 lbs of forage in hay and pasture. From 850 to 1300 he likely ate 2700 lbs of barley and 700 lbs of forage. So forage consumption is the 9500 lbs his mother ate plus 3000 700= 13200. Grain consumption is the 2700 lbs at the feedlot. Total feed required to produce 1300 lb steer is 13200 2700=15900 lbs. That would be 83% forage and 17 % grain. HT
          Semantics HT, pure semantics - you forgot to add in the bulls share of forage to produce the weaned calf. You work out a least grain scenario basing it on the cow never getting grain, the calf being back-grounded on hay and pasture only which the majority aren't. And the point of all this? so that Dave can discredit another levy paying producer who happens to produce beef by a different method. As Sean pointed out it is unfortunate that CCA monies are being used to fund this campaign against fellow producers.
          BTW it appears you don't in fact agree with what Kato posted - it wasn't me being devisive it was Dave and the CCA with you being quick to jump in on their side. What were you saying about glass houses and stones again?
            Good morning everyone. I thought I would shed some light onto why Dave Solverson was on Alberta Primetime. ABP/CCA gets media requests daily. The first rule of thumb is to never say "no comment" when a reporter wants your side of the story. If you are asked to contribute to the conversation, you are better off being an active participant rather than the one that wouldn't talk.
            As for the CCA mention....Dave is on the CCA board of directors representing Alberta.
              Lori,
              I don't disagree with what you state,
              however I do have an issue with a
              director being put into a position where
              they are in essence "facing off" against
              another producer in the same beef
              industry (although with a different
              production model). In my mind this is
              counterproductive at best and damaging
              to the industry as a whole. It is not
              grain vs. grass, hormone implant vs.
              not, or trying to prove that one is
              superior to the other.
              I think someone from ACFA or likewise
              would perhaps be capable of speaking on
              behalf of feeders without representing
              the broader "industry". I also do not
              think that CCA should be putting this in
              their news in an unbalanced way,
              regardless of what role the spokesperson
              plays in the CCA organization. I think
              due credit should be given to both sides
              in the production model debate.
              Just my 2 cents.
                Thanks Shaun. I will pass this information along.
                  We need to stick together! If we've learned any lesson in the past few years this should be it.
                  Somebody wants a big fat soggy juicy barley fed steak? We can do that. Someone else wants a real lean steak? We can do that. Someone yet again wants a steak produced entirely on grass? We can do that. Their neighbour prefers steak raised ethically? We can do that. If someone wants no hormones, or drugs, or organic, we can do that too.
                  This is my point. We all produce beef. We do it in different ways, but it's all beef. Different, not better. Better is in the mind of the consumer, and they certainly do not agree on what's best, so why should we? We should just all do the job in our own ways that suit our situations, and what we have to work with.
                  We can provide beef to fill whatever preferences there are out there. This is a huge marketing advantage, and one that the other meats do not have, especially poultry. There is some variation in pork, but only if you personally know the right people.
                  This is the message all of our representatives need to put out at all times, and they need to try and avoid this situation where they choose one over the other.
                    kato, I couldn't agree more. We need to stick together. What really bugs me is when agriculture people come to Canada because they don't like the system in their old country, and then advocate for things to be just like they were back home! Maybe we should have COOL for ranchers and feeders so we know who to take seriously.
