I have a portable water tank (1800 litre)that I use to water small lots of cattle on rotational grazing. I have a small trough mounted on the back about 12"w x 18"l x 14"d and have trouble getting a suitable valve for it. I have tried the Hudson valves that we use on our pipelines but it only fills a drip at a time. I have tried the cheap UFA valves that you are meant to screw a garden hose into but although they fill quicker they tend not to seal resulting in a steady drip. Does anyone have a suggestion of another type of valve? I want high volume, gravity fed from a valve that is physically small enough to fit in my trough. Thanks in advance.
Water tanker valve
