Mother Nature and Balance
    With all the moisture we've had, I was noticing today that the thistles seem to be coming with a vengeance this year. After a couple of years of drought and the grasshoppers etc., they seem to have a newfound growth spurt. Do you think it is just a coincidence that the Painted Ladies - who love thistles - show up in numbers that haven't been seen in these parts for a good many years now?
    I was out cutting down some thistles today and have noticed that many of them are getting black and have the Painted Lady catepillars all over them. I've left a patch of them to see just what these catepillars will do to them. My wish is that I won't have to get out there anymore with my scythe and get them down. With any luck the pupae larvae will kill them.
    How successful is cutting thistles in this climate Cakadu? It worked to a reasonable extent in the UK due to our higher rainfall which went down into the cut stalks and rotted the plant away. I started on the scythe too before graduating to a sickle mower - eventually most folk moved to a disc or flail type cutter which didn't work as well due,I think, to the stem being smashed rather than being clean cut leaving nowhere for the water to get in. I imagine you will suffer more from thistles than most - it's another byproduct of having sheep!
      Timing is definately important grassfarmer, but not just the rain. Pressure on the pasture in the spring will bring on the thistle of course. Like any weed, thistle is only there to fill a spot that mother nature doesn't want bare. We try to mow when the blossom is just on, and hope for a rain. Not only rain to run down the stalk but to give the grass a boost at the same time. Rotation is also key in the process. No cows in for a good long while after a clip.
      Found a shitload of these beautiful caterpillars on our Ponoka pasture where the thistles got away on me in a feeding area. I was going to mow, but decided to let these little beauties have their crack at them. I felt I would kill too many with the mower. Most plants had leaves stripped 70 to 80% and they seemed to be pretty hungry. I don't expect them to kill the thistle, but it sure has been exciting to see.
      Think any city folks get excited about things like that?
        I have had impressive results with Painted Lady caterpillars eating thistles in a field of lentils which had no chemical control available. The thistles were eaten down to a stalk with a sprinkling of thorns at the base. The caterpillars stopped eating after a while and the thistles recovered but they offered no competition to the crop and I was able to spray the thistles preharvest with Roundup and dessicated the lentils at the same time.
          Actually, just prior to the drought/grasshopper cycle, we were down to minimal thistles. We had rented the grass out and it was severely overgrazed for a couple of years, which is why we are now seeing the filling of the void with the species we don't want.
          I wouldn't have suspected that sheep would cause more thistles - why would that be grassfarmer? My guess would be that in many instances sheep are grazing pretty close to the ground (even forced to do so) which would give the thistles a chance to take off. Generally our sheep do not overgraze any one area and move around quite a bit. They do their fair share of taking the buds off of the thistles, which helps reduce the number that go to seed.
          It was one of the weed inspectors who told me to cut them off and let them "drown", so we've been trying that as well, hence the scythe. I'm actually getting pretty good with it. Like you Randy, I decided I was going to see what the catepillars would do in terms of destroying the plants. As the weeks go on, there seems to be more and more of them coming along.
          Since I recruited my husband on several occasions to come and help me, I'm sure it will not be long until there is a sickle mower in our future either. There's bound to be one at an auction nearby.
          By the way, grassfarmer, how has your collarbone healed up?
            Should have clarified that by "more of them coming along" I meant the catepillars.
              If you cut off the thistles now they will do their best to survive and go into a rosette stage? Bushy and short as they try to store up energy to survive and live another day?
              Everything will be geared to putting as much energy into the roots, instead of everything going to the seed heads for reproduction.
              Fall is the time to kill thistles...permanently!
              Cut them now, spray them around the end of August and the problem is solved...of course this won't work if you are a die hard tree hugger type! I guess the you just have to make sure you have a strong back and a sharp scythe?
                Probably got about as much to do with huggin trees as it has to do with unwillingness to line the pockets of mutinationals just to see overproduction of pure quality product and low prices. But that's just me cowman.
                  All information regarding MLA's salaries in available on the Government of AB. website. MLA's are paid a base salary plus a cost of living allowance, then a per diem for every committee meeting they attend.
                  Chair's of Standing Policy and other committees receive additional compensation.
                  I have no problem with the cost of living allowance as many MLA's keep apartments in Edmonton.
                  It would be interesting so see a comparison of salaries of MLA's across the country and find out if our MLA's salaries are above, below or mid range.
                  The province is currently reviewing compensation for senior officials, Deputy Ministers etc., so the review of MLA's salaries is timely.
                  If you feel that your MLA receives adequate compensation cowman, call him or her and let them know you aren't in favor of a salary increase.
                    I don't like spraying but do spray thistles when they are getting out of control. Have used mowers in the pasture as well.
                    They are tough to control along the creek banks where spraying isn't an option.
