Had the clutch replaced on baler.
Baled about a dozen bales of crap hay.
Happy it worked just fine.
I now have about 500 bales ready to bale.
it baled a few knotter messed up so got it fixed. broke a shear pin. now pto worked but large wheel on baler does not was told to ajust springs on clutch. Ok So do you tighen or loosen them? Tryed loosening them still does not work but when you roll the wheel back the pto shaft turns but it does not turn wheel to operate the baler. now have springs mesurements at 90 cm. I am mesuring from the plate the springs bolt to as it a solid starting point as spring cole is not a good start point. any help would be great as I would really like to get the hay baled.
Cathy
Cathy
