We were blowing the engine air filter out every day in the wheat. Now into this very dry dusty canola we are having major problems. The pre cleaner keeps plugging up, anyone got any fixes for this?
Have problem with engine air filter on CaseIH
join the club, been fighting that
for couple years.
if yours is an 02 with plastic shroud up top , its the worst.
you can fight trying to seal the leaks and get fine screens and improved seals for air screen .
your precleaner could have the tubes melted out. yes
spend lots at case for no results.
or get the air intake close to the height of hopper topper , with some kind of precleaner and screen.
now it's about 50% better than 2188
I checked the combine forum, some mentioned door seal and warped screen plate as some problem areas. Dusty dry canola seems to be the worst. We cannot make it a day after cleaning the pre cleaner, apparently it is the thing plugging up then the filter must take all the shit coming in. So we are working on it this morning. We had the filter housing off 6 times now to clean that pre cleaner, so we are paying some attention to door and screen seals. There is some chaff coming in some how. We are reducing our spreader speed more today also.
Hopper, here's a quick fix.
1. Loosen air cleaner bracket.
2. Remove combine.
3. Reattach to later model JD combine.
Should work. ;-)
found a missing part of seal from the screen suction to other side of radiator, supposed to suck the chaff off the screen. put in sponge seal and duct taped the connection was hoping it would help, but still only made it 8 hours. The same time a rub bar let loose and we had to go home anyway so down for the night, get parts and put things back together tomorrow. Oh we slowed the spreader to the point it was not working but had to speed it back to 350rpm to get even spread otherwise it was bunchy, its still spreading 30 feet. Adjusted the flaps down. No avail on filter problem. Can't believe no one got a fix for this. Dealer did try putting a snorkel intake on extending 5 feet above hopper, did not work.
It sounds like it has to be a leak somewhere
between that snorkel and the filter. Can you put
a leaf blower on the intake to put a little pressure
in the system to feel an air leak anywhere?
Please forgive the earlier joke, I was trying to
add a little humour, but realized it might not be
appreciated when you're dealing with a frustrating
problem.
