using edge/trifluralin through an air cart?
    Railway,
    We use an old 5t 50' spin spreader on autotrac to spread 21-0-0-24. Works great. Autorate scs460 Raven system with hydaulic drive on bottom drag chain... change rates on the fly... 125lb then to 250lb/ac on setting... can flip app rate back and forth on one switch. Can hook up to Deere 2600 (compatable with scs460) controler if wanted (about $1500 for system driver/harnesses plus the flow control, hyd motor and sensor... about another $1500.).
    To switch back and forth on Flexicoil air systems the Herbicide (10-15lb/ac and down is a cheaper system) to Fert (100lb/ac and up)... diff distribution systems usually provided than for low rate broadcast system. High rate (100lb/ac) uses normal seeding distribution system. Just the way they were built.
      I would find an old Morris. They are
      accurate, chain drive and have the two
      speed clutch. They have a good size granular tank on them and they should be
      dirt cheap. Back in the day we would
      spread edge while seeding peas with ours.
        hey railway my 2320 is a towbehind. Can
        still give you a call if interested. 306
        area code?
          He's at Estervan, My Guess 701 Code, Yankee Phone, CHEAPER RATES..............
            I would be a little concerned? about travelling at vertical tillage speed with an air cart? rough ground?
