Where do you guys buy your one inch air hose. This stuff I got on my drill is shit. ****ing stuff is cracked in two years. Last air tank I got (for air seeder) guy I bought from put all one inch black 75psi water line hose on. Told me black will last forever. Well it was three years since he had put it in and i had it for thirteen years, never changed a one except for a couple I lost. Fill me in guys, is this caseih white hose i got just shit. Thanks
One inch air drill hose
Originally posted by Klause View Post1 inch we just get the black water hose. Like you said, it lasts forever and it is very cheap.
For the 2" we are using the stuff John Deere sells... hope its better than the white/clear coiled stuff. Can't get a season out of that.
Agchat, you can likely get a better quality or price at Greenline Hose in Saskatoon.
I have purchased chemical transfer hose from them in the past and they will were about 10% the cost of an AGCO dealer wanted to charge.
https://www.greenlinehose.com/index.jsp?ID=,Industrial.Hose,Air.Hose,dept-1JN&path=to&ds=dept
Mine came with mostly 1" water line. I replaced a few worn out hoses with black factory type hose. Which is so brittle that it cracks and breaks the first time it is flexed, even new. While the water line goes until it finally wears right through. Needless to say, I picked up a bunch more water line to replace the worn out hoses now. Also, no issues with light getting through to the blockage sensors. I asked local plumbing shop if I could buy their short pieces, so they gave me the whole pile.
U Must be talking about wirsbo pex never tried it on the drill, its a dream for plumbing houses. Probably work great with the expansion tool no hose clamps and without the expansion rings. Going to have try that now as long as a guy can remove and reinstall easy enough. Could get it in red for seed and blue for fert if you wanted to get cute. Sun kills hose crazy how guys with 400k drills cant spring for a 15000 dollar coverall to store em out of the elements.
