Melting Arctic Sea Ice May Be To Blame For Endless Winter: Scientists It's an increas
    https://www.huffingtonpost.ca/2018/04/17/endless-winter-arctic-ice_a_23413520/?utm_hp_ref=ca-homepage
    It's an increasingly accepted theory among climatologists.
    Bob Weber
    Canadian Press
    Scientists are suspecting that not enough winter in the Arctic has led to too much of it across the rest of Canada.
    From Toronto, where ice storms cancelled baseball games, to Calgary where residents this week faced yet another heavy snowfall warning, April 2018 has come to feel like endless winter.
    Some climatologists say this is the future — long stretches of freakishly unseasonable weather that flip to something else on a dime.
    'From one extreme to the other'
    "It was looking like it was going to be the warmest December on record in Western Canada,'' said David Phillips, Environment Canada's chief climatologist.
    "Then it turned on you — several days of -30 C. It was from one extreme to the other.''
    In Ontario, Ottawa's warmest day so far this year was on Jan. 12 when the temperature hit double digits. That hasn't happened since.
    "They had their spring in February,'' Phillips said.
    The East Coast endured five massive nor'easter storms in three weeks.
    Why? Icy Arctic air is normally held back by a strong, high-altitude, west-to-east river of air called the jet stream.
    The jet stream is powered by the temperature difference between the Arctic and mid-latitudes. But the Arctic is warming faster than anywhere on Earth, especially this year, when temperatures at the North Pole were up to 30 degrees above normal.
    When the jet weakens, it tends to take these bigger north and south swings.Jennifer Francis
    That weakens the jet stream. And that, said Rutgers University climatologist Jennifer Francis, is the problem.
    "When the jet weakens, it tends to take these bigger north and south swings,'' she said.
    "When it takes one of these big southern swings, it allows all that Arctic cold air to plunge much farther south than it normally would and it tends to stick around there longer.''
    Hence, ice storms in April.
    Other factors at play
    It's not quite that simple. There are multi-year temperature cycles in the Atlantic and Pacific oceans that have their own impact. The Gulf Stream, which used to reliably move warm water around the Atlantic, is weakening. And this was a La Nina year, when lower sea and air temperatures in the Pacific brought more cold and snow to much of North America.
    Many scientists aren't completely comfortable directly linking melting sea ice and weather.
    "There is likely some connection, especially early in the winter,'' said Faron Anslow, a climatologist at the University of Victoria.
    "It's being studied, and single events or even sequences of events can't be tied to that cause yet.''
    Phillips, who called this winter unique in his 50 years of experience, believes there's something to the link.
    "There's so many different factors at play. But I think it comes down to that very simple reason why the jet stream is wobbly rather than straight — the gradient of temperatures between the north and south is less.
    "That is the major climate control to the position of the jet stream. And when it weakens, it wobbles.''
    I don't think you'd find a scientist who'd say there's nothing going on.Jennifer Francis
    Evidence for a sea-ice link is building and at least 15 recent papers have found a connection, Francis said.
    "I don't think you'd find a scientist who'd say there's nothing going on. The events that we've seen in the last few years are very consistent with what we'd expect.''
    Arctic sea ice isn't recovering. So if the effect on southern weather is real, look for more of the same, said Phillips.
    "It's the preview of what we're going to see. The circulation has changed. It's almost a fundamental change in our weather.''
    You propagandists just won't stop, will you !
    So devoted to your religion.
      Winter ended yesterday , within normal range, not out of the ordinary .
      Move on to the next sliding scale of dramatic climate change event.
        We need to fire every one of those stupid idiots that work for environment propaganda Canuckistan starting with Phillips. Melting sea ice is responsible for long cold winters. Good one. Who paid for this? Time to cut tax funding to this ridiculous and absurd junk science.
          This is nothing. Climate change was much more severe in the 1930's.
            These guys are the Dennis Gartner of weather .... I'll go out on a limb and say after later start we burn up and govt will be back to warming... 🤣🤣🤣🤣🤣 always reactionary never actually forcasting. Plus they admit to a cyclical pattern in weather yet we've interrupted it by staying warm ... maybe it's the cycle and not us.
              May 23rd start in '74.
              Maybe this internet media thing is similar in a way to journalisms beginnings.
              Newspaper owner directed editor closely. Hearst could direct public info and opinion as newspapers were all there was.
              Today everyone with a smartphone is a journalist. Facts immaterial.
              General public just as malleable.
                Fire the f’er. I am tired of paying for this slop. All through the fifties and seventies we had many late springs and spring storms across Canada.
                  No, devoted to science and willing to consider evidence on both sides of the argument. Long before this article, and the exact same arguments I made last week on this site, credible scientists have been predicting global warming at poles would lead to shifting of the jet streams, and more intrusions of arctic air masses and storms into mid latitudes. You were all claiming last week that the cold spring proved there was no global warming. Yet the best reason you could give for the cool spring was lack of sunspots, yet not one of you could explain why the sunspots did not cool the Arctic. None of you are even willing to consider that the cool spring could be in part reflective of global warming.
                  Another interesting story yesterday in the Globe and Mail https://www.theglobeandmail.com/canada/article-in-tuktoyaktuk-residents-take-a-stand-on-shaky-ground-against-the/ https://www.theglobeandmail.com/canada/article-in-tuktoyaktuk-residents-take-a-stand-on-shaky-ground-against-the/
                  Now for those claiming warming temperatures do not have a negative impact, read this story.
                    Total lying bastards, sick of COLD because it's TOO HOT, F*CK OFF ALREADY!
