Melting Arctic Sea Ice May Be To Blame For Endless Winter: Scientists It's an increas
    so just imagine for a second that humans wanted to warm the planet by melting the icecaps.....here's the math.
    https://wattsupwiththat.com/2018/04/16/can-humans-melt-the-antarctic-icecap/
    so if we wanted to warm the planet it would take thousands of years of purposeful trying, but by not even trying now the planet will burn up within a decade?
    To think a carbon tax on a small insignificant portion of the globes population will somehow mitigate global warming is just insanity. or worse it is a globalist plan to indenture each and everyone of us into servitude for a government bent on destroying freedom.
      you are absolutely right. So provide me with the verified and irrefutable facts that you must have to make the claim that sea level rise is not accelerating. I am more than willing to consider these with the same nuances that you use to dispute the 4 studies I linked. But you back up your claim and until I see such studies and have the opportunity to judge their credibility, I am sorry I will not accept your word for no change in sea level rise.
      As I said before, I'm a little busy calving cows and preparing for a wet muddy spring to go and do a bunch of research. If you do a Google search on the subject, you will find a lot of reputable scientists who have already done the work. You will also find a lot of people muddying the waters, confusing Continuation of a trend with acceleration of a trend.
      Or better yet,Obtain the original data and verify for yourself, don't believe anything.
      It is no coincidence that the a GW side always has to invoke belief in their arguments, Just like any other religion, Belief trumps facts.
        I doubt that any science will change the mind of the die hard conspiracy theorists.
        I don't see many farmers questioning the impact of El Nino and La Nina. They both have impacts on weather and crop production in various parts of the world. Market analysts look at them.
        It's not much of stretch to imagine that if the arctic is sometimes warmer than the mid latitudes and that it may have an impact on the jet stream and weather patterns farther to the south.
        This isn't a new theory it has been around for awhile. Maybe we are seeing the results first hand?
        I don't think there is a government in all of Canada, including the Saskatchewan Government that doesn't support the current science that shows humans are causing relatively rapid climate change.
        The Saskatchewan Government may not support a straight up carbon tax, but they spent 1.2 billion on carbon capture at Boundary and are openly admitting that human caused climate change is real and a serious issue to be concerned about.
        I am just wondering why they are not listening to the handful of amateur conspiracy theorists on Agriville if your arguments are so convincing?
          "...or worse..." - would be the accurant an$wer.
          $earch "UN Agenda 21" and "Agenda 2030..." and you will have your an$wer. The co$t of "$aving the planet" a$ outlined i$ clearly $tated in the$e UN document$. Read it for your$self - it'$ all there in the open.
          It i$ the mo$t audacious tran$fer of wealth ever undertaken on thi$ planet: "How much will Agenda 2030 cost? Various figures have been thrown around by UN bureaucrats regarding the monetary costs of the plan, generally ranging between $3 trillion and $5 trillion per year..."
          https://www.thenewamerican.com/tech/environment/item/22267-un-agenda-2030-a-recipe-for-global-socialism https://www.thenewamerican.com/tech/environment/item/22267-un-agenda-2030-a-recipe-for-global-socialism
          So, the global overlord$ just love $imple-minded goof$ or "u$eful idiots" who drink the Gorakle'$ koolaid and eat $uzuki'$ crap and play hockey with Mann'$ $tick and thu$ help them $pread their propaganda and force public opinion...
          dlm, forage, grassant, chunk chunk...thanks for helping the New World Order spread its stinking $4!^
          $tupid peasant$ who enable the very one$ who will pick their pocket$ clean.
          "Government: the disease that masquerades as its own cure".
            Plastics in oceans, there is a microbe for turning it back into oil, but is there a salt tolerant one? There is money in stacking traits.
            Ocean water freezes at 28.4 degrees F. Diluted ocean water from all that dml confirmed about arctic mainland, and off mainland ice sheet melt would lead one to believe that the freezing point of the ocean water would now be somewhat higher. With the North Atlantic conveyor belt also slowing, and mixing of fresh and salt water not sinking nearly as actively, I would think that the Arctic Ocean has gained some ice building capacity.
            Of course if you want to believe that that has been overwhelmed by 30 degrees C increase above historical, then I guess it is permanent clear sailing through the Northwest Passage. Forget the cows, dml, a northern cruise is what you need. It's far more important for you to confirm sea level rise.
              It's not much of stretch to imagine that if the arctic is warmer than the mid latitudes and that it may have an impact on the jet stream and weather patterns farther to the south.
              Yup, warmer there tha mid lattitudes for sure..
              https://www.weather-forecast.com/maps/Arctic?symbols=none&type=lapse
                It is really quite amazing how nature's pendulum only swings so far before the very action itself sows the seeds of it's own destruction. Holds true for ice ages.
                  I think there should be a continental drift tax to save the North Atlantic current temperature conveyor belt.
                  I see you get that the planet should be more concerned about an ice age than global warming. Why can't you stick to that? We will need plenty of GHGs to stop the cooling.
                    Burnt you hit the nail on the head. Its all just a scam and it is stealing money from the every day Joes.
                      Perfect answer burnt!
                      Major collaboration of EVIL SOB's hell bent on wealth transfer.
