Hydrogen fuel cells
    Hydrogen fuel cells
    Amazing the amount of power you can get out of a home-brew fuel cell.
    Simple to build.
    Water is the only byproduct.
    Generating hydrogen from solar/wind is easy enough too.
    Imagine running a farm on a swarm of 'bots' that have only water as an emission... and no fuel to buy.
    Giver
      Klause for king!
        I have a question.
        If it's so easy....why isn't it being done or replaced fossil fuels already?
        It isn't a "new" concept.
        I don't buy the Oil Industry squashing it argument either.
          It's not the environment that's the issue it's tax. No way are alternatives going to be allowed if no way of taxing. Big oil is govts workhorse and in exchange they got a monopoly. I find the history of prohibition, ethanol, Ford/Diesel(the men) very interesting and explains how we got where we are. Crude by products where not the original fuel sources, was all plant based. One option that's being mentioned is taxation by mile. Gps or odometer readings to govt at time of licencing. The electric/ hybrids are already cutting into revenue so they need another scheme
            I have a question.
            Generating hydrogen as a way to store solar or wind energy is not efficient nor easy. Hydrogen is very light and to get decent energy density it must be compressed to a very high pressure, think hydrogen bomb. Why not use the generated electricity without converting to another form of energy? Well the problem is battery technology. Lithium ion batteries get us closer but still have their drawbacks. Like recharge time, cost, and occassionaly spontaneously combusting.
            The more a guy researches the subject the more attractive diesel fuel looks as an energy source. Its relatively safe, has a high energy density, is easy to store and pump, fairly reliable. Solar and wind just do not cut it. Often the wind does not blow and sky becomes cloudy. Until we discover cold fusion, can extract energy from the ether or wirelessly transmit large quantities of electricity there will not be a viable alternative to fossil fuels. Hydrogen fuel is a pipe dream imo.
              I have a question.
              Because fuel cells are not an energy source, therefore cannot replace another actual energy source such as fossil fuels. They are a very inefficient means of converting energy into a form that can be stored.
              The green side likes to trot out fuel cells as somehow solving an energy production problem. Similar to how they misrepresent electric cars as being emissions free.
                He gets it, not only is using 'free' electricity to generate hydrogen almost a net loss but it is a very dangerous energy store.
                  Not really.
                  Not anymore.
                  There's 8 types of hydrogen fuel cells. Some of the exotic ones are very efficient... The US military uses fuel cells to power all their bases because it's incredibly "clean" power... and when you count on heat usage efficiency is on the order of 85%
                  You can make diesel and gas cars work on hydrogen too... Injected through the airstream. Go from 10mpg to 60+
                  There's also a very big difference between hydrogen storage and a hydrogen bomb. Equating the two is silly.
                  You can store the hydrogen in the form of NH3 too. Makes it inert.
                  Armchair scientists on here... yet DARPA, SCRAM, and the AATIC have it figured out...
                    Not really.
                    Not anymore.
                    Perhaps the terminology is confusing me. You state the bases are powered by fuel cells, that may very well be true, but what is the energy source for the fuel cells?
