Auger motor engine heaters
    Have had a lot of trouble starting kohler motors at -20 and colder
    Put one of those stick on rubber heat pads from canadian tire and works great
    Yesterday minus 32 with it plugged in and a couple coats overtop started like summer
    Hand Priming pump helps to. The brant conveyor that showed up in the spring has one.
      Are you talking about the Koehler with the high set carb with the intake exposed? They are a cold blooded beast. I have a couple with the low set carb and cold kit. They’re decent starters but if you could warm them up it would be easier. Dad used to use a stove pipe and tiger torch but those engines didn’t have all the plastic
        What are you doing hauling grain at those temps?
        There must be something else you can do in the house? LOL...
          thats the problem , too many jobs in the house
            Okay so I can start my motor but can’t move my self-propelled auger. Even detached the hydraulic motors that drive the wheels and tried to warm up the system by circulating oil but it was complaining so much I quit. Too cold nothing works right I guess!?
              That's the problem with every thing plastic, oil tanks, engine shrouds, tiger torches are forbidden.
                What kind of oil in the hydraulic system. Bought a auger in 13 or so and that one moved way better then the 08 model. Asked the dealer said different oil in the 13, but sold us some additive and and added that and it is way better.
                  Usually carry around those little propane bottles with torch end and direct the propane into the intake really helps for starting in the winter.
                    I heard of using a tiger torch over the intake to run the auger. Propane injection.
