Originally posted by WiltonRanch
View Post
Auger motor engine heaters
I use a small heater or interior car warmer for 1 -2 hours with a couple of old parkas to cover the engine. Works well.
Originally posted by caseih View PostHave had a lot of trouble starting kohler motors at -20 and colder
Put one of those stick on rubber heat pads from canadian tire and works great
Yesterday minus 32 with it plugged in and a couple coats overtop started like summer
Guest
Originally posted by Livewire View PostOkay so I can start my motor but can’t move my self-propelled auger. Even detached the hydraulic motors that drive the wheels and tried to warm up the system by circulating oil but it was complaining so much I quit. Too cold nothing works right I guess!?
this one moves fine after disengaging wheels and circulating oil
i presume you are covering air intake as well?, we just have a 12" circle of tarp hanging on a zip tie and throw it over after engine is running
Guest
Originally posted by AC man View PostIs your kohler a fairly new motor? I have one of the old blue 70’s vintage single cylinder kohlers that starts in minus 30 or colder with out heat. I have 0w-30 synthetic oil in it and have the battery in the heated shop overnight. I rarely used any heat on it. It was common to be called to haul malt barley in minus 30 weather.
But good engines
We always use 0w30, and ATF is very good for cold
Originally posted by TASFarms View PostATF works good in the cold for hydraulic oil.
