What is Fair for Parts?
    Originally posted by Austrian Economics View Post
    Calling parts prices "atrocious" is not an argument. If you think a part is priced too high, it's incumbent on the person leveling the accusation to explain what the correct price ought to be and how you arrived at that conclusion.
    Here's the counterpoint.
    Anybody that runs Massey understands what this is, on the left hand of the rotor.
    This piece from AGCO is $879.
    I drew it up in CAD and sent it to a local fab shop. Metal, bending, drilling all in $121.
    The part is 2 days away from AGCO. The fab shop had it done next day.
    Is 750% over actual value, fair?
    The market doesn't bare this, it is forced to accept it.
    I had a casting on the intermediate drive to the chopper break....184 hours....the replacement broke in 80 hours in the exact same spot....
    It was a casting failure since you could see the paint got into the crack...
    And they want to argue about this...and send a mechanic out to see how my 200 hour combine is running...
    Its fine ...your phucking parts are garbage...
    AND I won't be able to afford the combine if it keeps breaking every 80-100 hours...
      I had a near legal case with Massey on their combines . I laid out the cost of my down time due to their failure in the machines
      Downtime on any combine is easily $10,000 / hr on most machines . They backed down very fast when we sent a detailed letter from a law office .
      It should not come down to that but you have to stand your ground when you are right .
      Otherwise the ag industry thinks they can simply continue on charging outrageous amount for machinery and or parts .
      If they want to charge outrageous amounts it better work as advertised. And don’t take a farmers time and or downtime for granted
        that is nothing case ih charges me 6 dollars a bolt and need 80 of them all individual wrapped it is nuts what they charge
          Seems there is no shame, but don't take your frustrations out on the parts counter employees....unless.they're assholes. Those parts prices are set higher up the food chain.
            That is a perfect example of the price not having to be super high.
            Its the lack of "value" that stings just as much as a large sum of money.
              Cab fan on a 9300 4WD, $400, EXACT same fan slightly different mounting for a Sterling tandem,
              $150.
              9870 and other JD combines, the hyd swivel at end of rotor variable drive sheaves, half the size of a Styrofoam coffee cup, $450. Very specific non generic part I guess.
              And yes most have a STUPID design that costs us $$$. Deere engine fan drives, 70 series and early S.
                "I drew it up in CAD and sent it to a local fab shop. Metal, bending, drilling all in $121.
                The part is 2 days away from AGCO. The fab shop had it done next day."
                I've done this myself several times at a considerable saving. But I've done it when I have time to measure up the part and create it in CAD, (which I own software for) which most farmers either don't have time for or don't care to do.
                There are lots of manufacturers, like Shoup, which specialize in aftermarket parts. But these parts tend to be high volume items subject to frequent replacement. These parts tend to have a lot of application in multiple makes and models, as is the case with cab insulation which cuts different patterns of the same basic product.
                This is generally not done for lower volume items in more specialized areas because of the considerable cost of inventory. Then there is also the need to keep pace with frequent model changes and dealing with the possibility of an incorrect measurement resulting in a part that doesn't fit. This market is generally filled by the wrecker yards which don't have to recreate parts but merely disassemble them. If there was money to be made in creating new versions of a broad area of repair parts, someone would already be doing it.
                Anyone making of business of this (or any other business for that matter) faces substantial regulatory and compliance costs the moment you have employees. Most have to get large enough quickly just to afford a dedicated HR department to deal with the minefield of hiring and employment practices.
                  Have never seen that program before. Does it work good?
                    https://en.m.wikipedia.org/wiki/AutoCAD
