Gas in diesel ehgine
    Other day took slip tank to get a bit o diesel for the chore tractor. Told her put 100 litres of diesel in slip tank, fill truck with gas. Brought it home put some in tractor. Tractor ran and fed a couple bales. Tractor died when I went to go again. Bled lines, tried everything, no gas smell. But today as I worked on it, cracked a line, smelled GAS. Ran to the slip tank, yup, GAS.
    So I assume the coop has insurance or such. Anyone have this happen to them? Ie what if engine is damaged?
    Talk to them immediately, give them the heads up? Or find the damage and go from there?
    Just hoping not much damaged.
    Thanks for input.
    Does your receipt show 100L of diesel purchased?
      Will have a look
        Gas will wreck o rings. Can get away with diesel in gas but not gas in diesel.
          100 l of gas on receipt.
          Yeah I’m draining the tank and lines and am gunna get some diesel to try and get her running and see if anything is amiss to start with. Gas hard on injection pump etc.
          Worst is I gotta get bales out to the sheep. Kind of need that tractor...
            My dad put gas a couple of times in a David Brown we had, never seemed to have the same amount of power it originally had. Eventually needed engine work.
            Were you thinking one thing and said another to the gas pump operator?
            Not sure you have a leg to stand on regarding Co-op insurance, so many things could have happen after you left the service station. How do they know if you didn't screw up at the farm?
              I think you might be screwed with getting help from gas station (receipt shows you left ‘accepting’ the gas purchase). Not sure on the engine damage.
                Well I got her drained out and lines cleared and fresh diesel in. So far so good. Talked to gm. They certainly WILL stand behind me if I have issues. They will cover me. I always state, diesel in tank, gas in truck. I know I stated that. “Who the #$&@ hauls gas in slip tanks?” said the gm to me. Lol
                So I guess I was thinking the worst, expecting the worst, and maybe got ahead of myself. We’ll see what happens in the next hundred hours.
                Talked to a gm friend of mine in a far away town to get his perspective. Being local, knowing the service centre manager, and having receipts and knowing dates and times etc., it’s pretty easy for them to cough it up. If I was a non local, and had no reputation with the place, he said it would be harder, though not impossible to rectify. They carry piles of insurance he said. For just this kind of thing.
                Me? I’m just thankful it appears no immediate damage was done, and I can feed my sheep on schedule without trying to find a rental or something.
                Anyhow, as usual, thanks for all the replies.
                  Years ago Esso delivered bulk fuel and put gas in our diesel tank. One newer diesel truck came to a stop like your tractor. After changing the fuel, we got it going again. Shortly after, the fuel pump and injectors needed to be replaced as it had low power and smoked. Esso paid for all the repairs-mind you, the chain of custody of the fuel was pretty obvious in our case-still was gas in the clearly labeled bulk diesel tank.
                  I would notify Co-op right away, show them the slip tank etc. They will be inclined to work with you I would guess.
                    A small amount of gas in diesel doesn’t seem to do damage. I used to have a rabbit vw diesel and the owners manual recommended in freezing weather to add 10% gas to summer diesel if winter is not available.
