Oil changes
    Oil changes
    When do you do your oil changes on your equipment?
    I used to do then every fall before they got parked for the winter. Then I went to an oil seminar put on by our local Petro-Can dealer. The speaker there ask the crowd that same question and most people said fall and he replied that fall is not the best and spring would be better. He went on to say that during the winter you get a lot of water in your engine from condensation and that water will be in the oil all the next summer.
    I don't like the idea of dirty oil in an engine all winter but think it might be worse having water in the oil next summer.
    Typically fall is best. Added moisture dispersing qualities expire and the acidic contaminants accumulated are best removed for long term storage.
      If it's time for an oil change then I'd do it before winter. I'd be much more concerned about combustion contaminates then a little H2O that will mist off out the breather the first time you drop the drill in the ground.
      Don't think anyone changes the transmission oil every year because of condensation.
      Likely not a bad idea to see if any water comes out the drain in the spring after the engine has not ran for months, as long as a guy can do it without making a mess. Also do an oil analysis to see what's in the oil. Cheaper than throwing out 45 liters of perfectly good oil
        250 hours whenever that may be
          When is the last time anyone had an engine failure that could be blamed on oil?
          I think a lot of this concern about engine oils dates back to a long time ago when lubrication related failures were common, with the poorer quality oils of the day, and poorly engineered engines with much looser tolerances.
            Ahhhh you just need some old equipment like the 3208 in my feed truck that gets a gradual “oil change” every 100 hrs or so due to blowby, burning, and leaking. Just spin a new filter occasionally when it crosses your mind. 😎
              Originally posted by wiseguy
              The retailer says 500 hours with John Deere oil !
              It's better !
              The owners manual in my new combine says 600 hours !
              Not better,,, they just like to see you bring your equipment back to the shop for SERVICE ! lol
                All equipment gets changed once a year in the fall, don’t care if it’s 100 hours or 300 hours. At present time we have no equipment that runs more than 300 a year.
                  Sounds familiar.
                  But ironically, that is one engine that actually does need very regular oil changes, and scheduled bearing rolls, to avoid catastrophic bottom end failure.
                    Mainline seasonal equipment here gets stored with clean or near new engine oil always.
