Dutch precision edge
    New drill prices have me throwing up in my mouth a bit. Decided to put money into my current drill and run it for a few more years. Currently run a flexicoil 5000 type drill with Dutch low draft openers.
    Was snooping around last year and looked hard at the atom jet high rate side band, but wanting to continue paired row if I can help it. Or is the high rate side band THE way to go?
    Anybody using the Dutch precision edge? Looks interesting.
    Looks interesting.
    Looks sort of like a boat anchor.
    We went totally backwards these past few yrs. With the dry springs we have gone back to narrow tips on the drill. Our N and S is now coated and going down broadcast ahead of the drill. Trickle in some phos and ESN with the seed. Easily cuts down a few days at seeding, way less HP and fuel. Seed durum and lentils at 5.5 mph now.
      If I remember Dutch precision edge reminds me of a stealth opener. I remember going from stealth to Dutch low draft and remembering 2 things that they pulled easier and pulled up less rocks. Was never happy with canola germ on Dutch low draft. In 2014 when I bought my present Flexicoil 5000 I had atomjet 3/4 inch side band openers put on it. I thought it hurt my cereal yields and put fertilizer to close to the seed on canola. Then I went to 1 inch atomjet high rate side band. With cereals tried putting seed out the side and out the back. Works way better out the back, only downside is fert does plug once and a while going out the side. With canola put seed out the side, fert out the back works awesome. This year did an interesting trial. Neighbour had some Sirish seed left in his drill. Seeded 11 acres, he uses Dutch low draft. I seeded Austenson beside it. Our fert was close to the same. We did 3 replications down and back with the combine, each was approx. 2 acres. Weighed in our cart. Austenson out yielded it by 3 bushels per acre. The point is in my opinion the atomjet didn’t hurt the yield, have to admit I was surprised. Both varieties were certified, seeded at 3 bushels per acre. I use seed treat, he does not. We use 41/4 inch rubber capped packers and I don’t have the harrow closers on the drill, always seemed to plug with trash. The one inch stealth high rate side band do pull harder than the standard side band but in my opinion pull less rocks than either stealth or Dutch low draft..
        It is a lower disturbance version of the regular Dutch precision is it not? Very narrow fert trench with a sealer plate that tucks the seed into either side of the trench? I understand it will move more dirt than a 1 inch single shoot opener, but I think it will be way less than a flexicoil stealth. The Dutch precision was a fairly good opener in my understanding. This seems to improve on that design in my mind. Although, we desire different qualities in the north I suppose than around Regina. Making a distinct black furrow to warm the soil up is high on our priority list.
        What is your opener of choice jazz?
          Yes. Dutch low draft work well in cereals, but fall behind on canola in my opinion as well. That is the reason for looking at switching.
          I do not like shattering the seed bed below the seed like the precision/stealth do. Do the atom jet hold up well in rocks? Seems we have our fair share up here. How wide of a seed row do you achieve by putting the cereals out the back? Would it hold a swath up on 10” spacing?
            I do like not shattering the seed bed below the seed like the precision/stealth do. Do the atom jet hold up well in rocks? Seems we have our fair share up here. How wide of a seed row do you achieve by putting the cereals out the back? Would it hold a swath up on 10” spacing?
            I have only knocked off a couple of carbides in 6000 acres. The stubble would be roughly 21/2 to 3 inches wide going out the back and 11/2 to 2 inches wide going out the side imo. In a year with good yields no problem. I roll all my cereals so if I am concerned when swathing I cut at 90 degrees to the way it was seeded if possible. You can get them with a 3/4 inch Center or 1 inch Center I believe. If I ordered them again I would be tempted to try the 3/4 inch but that might be counter productive as it would narrow the seed row.
              The Dutch opener would have better seed and Fert separation but the fracturing of the soil might hurt canola germination, not sure. I certainly think the Dutch precision opener is interesting, tough call.
                Yes. It seems to me there is a poster on here that had the precision edge when they first came out, but I cannot find the thread now. My concern is tearing the seedbed out with that knife down the middle…especially when it gets dry. Otherwise looks pretty good.
                I really like your idea with the atom jet of switching the cereals out the back to achieve a wider row. Makes the decision very hard now!🤣
                  We were using a Dutch 3.5 inch spread tip putting all our fertility down with the seed using ESN.
                  It takes big HP to pull that when seeding 2 inch deep in wet gumbo.
                  But it had a draw back. When wet pulls up lumps, when dry pulled up lumps too and made for a very uneven seed bed and uneven emergence.
                  I dont have the budget to replace drill and tractor so we went back to broadcasting and seeding with 3/4 inch bourgalt knives. Much less disturbance.
                    Sorry, didn’t mean to complicate your decision, it is a topic I have thought a lot about.
