Lead in aviation gas could be replaced with sustainable aviation fuel.
    Thought this deserves its own thread, since it was buried in a resurrected old thread about a completely different topic. Credit to Larry Weber for bringing it to our attention.
    eliminate lead exposure, and ensure cleaner air in and around airports;
    Learn something everyday. I did not know that lead was still used in aviation fuel. Or that sustainable aviation fuel can eliminate that lead, the same way it does with ethanol replacing lead and MTBE.
    Hard to believe that we have been waging a war on completely harmless CO2( plant food) while still allowing aircraft to pollute the skies with lead whose health consequences are dire and have been known for centuries. There literally is no known safe exposure limit for lead. So we put into an internal combustion engine and disperse it into the atmosphere where its residence time in the broader environment is measured in centuries. Then wonder why we are losing the was on cancer.
    So airplanes get a free pass, But fertilizer emissions and cow burps are the problem.
    While I question the sustainability and economic feasibility claims of biofuels, this is one argument in favour of biofuels that cannot be refuted.
    AF, maybe you havent heard, its now about destroying western racist capitalism. Greta just told us.
    There are literally thousands of low hanging fruit type initiatives to tackle any concerns about the environment and they are all ignored. Have been ignored for 30 yrs.
    You are trying to employ reason where none exists.
    Right now the COP conf has 4000 attendees that flew in on 400 private jets.
      Environmental issues are about wealth transfer and that pretty much explains it.
        I was told by a Commemorative Air Force pilot that the big radial piston engines in the old warbirds had an exemption (US) as they needed the lead. Otherwise they could be grounded. Maybe there's a replacement now, dunno.
        Those engines still in use under certain apps for their torque. Maybe somebody who knows can comment.
          Ok, so google says still lead in all avgas. Piston aircraft.
          Likely not jet fuel.
          222,600 registered users in US.
            I assume a jet turbine isn't capable of detonation, therefore no need for an anti knock additive.
            Here is a short read on the topic and health consequences of lead:
              https://www.federalregister.gov/documents/2022/04/18/2022-07598/renewable-fuel-standard-program-canola-oil-pathways-to-renewable-diesel-jet-fuel-naphtha-liquefied
              Old again; however, the new RFS for diesel and aviation fuel could change the dynamics of crop pricing and land prices as much as ethanol did from 2005 to 2012.
              Its why everyone rushed to Regina to build (better yet - announce - cause I don't think anyone has started with 25% inflation) crush capacity; the dynamics of vegetable oil: domestic use and exporting will change forever in the new RFS for aviation fuel - regardless of the leaded portion (AVGAS LL) which is i think is 20% of the use of jet fuel in the USA.
                Still not sure where the additional canola will come from.
                If we were to follow responsible rotation recommendations, then canola acres would need to fall significantly. Unless there is something new in disease resistance or treatment that will make back to back canola more viable.
                We don't seem to be winning against club root or flea beetles.
                I am on the fringe of grain production, and even here there isn't much good pasture or bush land left that could (or should) be converted to crop land.
                To push the boundaries any further would require some adaptation to be more frost tolerant. Or water tolerant or drought tolerant, depending which direction you want to expand.
                Climate change doesn't seem to be helping to expand the arable acres.
                Fertilizer restrictions, drainage restrictions, regulations, all handicap efforts to increase acres or yield.
                Our county still can't approve acreages fast enough, let alone all the full quarters that become horse pasture and atv playgrounds. They are out of production possibly for a long time.
                And in spite of the higher oil content in canola vs soybeans, can we really compete in the industrial oil market when there is no oil premium? Takes a lot of expensive fertilizer to grow canola vs soybeans.
                  When all those bio plants were announced California and others had mandated levels of biodiesel I think based on some carbon credits monetization.
                  It appears the values of the credits has drifted lower to about 25% of original values.
                  I think the incentive to blend was based on the value of those carbon credits.
                  I'm sure somebody understands it better than me as I don't get the whole carbon credit pitch as it appears to be a ponzi.
                  The guy issuing the paper seems to always want the majority of the profit.
                    Avgas ( 100LL ) is able to surpass the rating of Mogas by as much as 15 octane thanks to the addition of this lead additive. The result is a more stable engine less prone to spontaneous and catastrophic failure.
                    It's a safety thing. Can't have airplanes falling out of the sky crashing into houses. Also, there is no safe alternative yet.
