Help a stranded aussie
    Did a cleaning bearing on Claas 670.
    1 fan section NFG none in oz.
    Any dealers there got any?
    Plastic circular fins.
    If I can find some be going in 6 days
    Many wrecked 470 570 cats
      Best dealer here is fosters in beaverlodge, call them.
        Posting a part no would help
          Sorry brain fade
          Part number 0007365501
            Phoned fosters 0 in Canada 3 in USA 71 in Germany.
              That would make me sick. I would have to rent/buy a machine from the dealer.
              Any brand differences for parts there?
              Does that happen often? Good luck.
              A Machine Down part order usually gets expedited fairly well. Let us know.
                Seen ad on Kijiji from Combine World for salvage 760, not sure if part would be same or not though on that model.
                  Take the bearing and do the tour of dealerships and bearings houses if close. If not close take a picture & get dimensions to send info to suppliers above. Hopefully you can find a bearing.
                    Bearing not the issue I believe it took the cleaning fan out when bearing failed.
