CCC Blackleg and canola rotation
    Seems the canola council agronomists are recommending rotating from liberty to roundup or vice versa in order to reduce blackleg issues.
    Problem is, they don't know which geno type is in the field, they don't know which type of resistance is in which variety, that resistance is not based on herbicide tolerance, and that rotating varieties within the same company may even be better than guessing who has what resistance.
    Why would the council be stating this since it sure is not science based in any way?
    The different herbicide systems come from very different germ plasm, therefore have different inherent characteristics. The trouble with switching withing RR varrieties is the fact that several different companies may source seed from the same breeder. i.e. Canterra, Brett Young and FP all source alot of varrieties from DL seeds. Though I agree that this is a over simplified recomendation from the CCC. It would be far more helpful if the seed industry would adopt the practice of publishing their resitance. TKW and nutrient response curves would for everything would be nice to see as well.
      It is not that simple Ado, for blackleg there is an interaction between the pathotypes in the field and the genes in the variety of interest. So just knowing the source of resistance doesn't mean a lot. Biology isn't always usually simple.
      Maintaining at minimum a 3 year rotation is the only guard against this. People grow back to back canola then try to push even harder and justifying in their heads that if i rotate liberty then roundup, i'll be ok. Not good agronomic info.
      DL breeds seeds for other companies yes, but do not use those varieties for their own use. They may have their own varieties which may have different resistance then Brett's or Canterra etc or liberty for that matter.
      It just is not known which varieties have which resistances, sources in individual fields and how they react, it is a crapshoot. That should be the message on short rotation canola.
        Recommendations should be based on scientific data. Not just give an answer that seems or sounds plausible and easy for farmers to understand.
          wd9
          Did you hear the CCC agronomists make that recommendation or did you hear it second hand? You are right that rotating herbicide systems won't do anything for disease. However, CCC agronomists and others have discussed rotating herbicide systems as a method of controlling volunteers because volunteers can act as a disease bridge. Perhaps this was the context in which this point was raised?
          Ward Toma
          General Manager ACPC
            I am an agronomist with the Canola
            Council.
            I am fairly certain that we emphasize
            very strongly to canola growers to use
            long rotations along with resistant
            varieties to control blackleg. That is
            our first message, always.
            But we do know that growers are using
            shorter rotations, and that puts them at
            risk. Also, we do know that using the
            same variety in a tight rotation is a
            high risk for selecting races of L.
            maculans (the blackleg fungus) which
            will overcome the resistance in that
            variety. So our message for growers in
            this situation is to:
            1. DO NOT use the same variety in a
            tight rotation
            2. increase blackleg scouting regime to
            determine risk
            3. use a fungicide if high levels of
            blackleg are observed in the early
            season
            wd9, you are correct in that we do not
            know what varieties have which
            resistance genes and what races are
            present in which fields. What we do know
            is that using the same variety is a high
            risk (and there is a lot of scientific
            data that shows this), so using any
            other variety is a better choice. The
            good news is that most breeding
            organisations claim to be using multiple
            sources of resistance; so there is
            diversity in germplasm within the
            market, within herbicide systems, and
            within breeding companies. So we are not
            in the position to recommend which
            varieties to switch to - yet. The
            industry has agreed that one of our top
            priorities is to get to work on
            identifying resistance genes and to
            develop methods to test for L. maculans
            races. We are a few years away from
            getting to this point, but the work has
            begun.
            But again, the best choice is to avoid
            this high risk situation by employing a
            longer rotation - and this is our key
            message. But if growers do make the
            choice to take on this higher risk, then
            they need the right information as to
            how to do it so they do not endanger
            their farm or their neighbours (by
            selecting for more virulent races). And
            that message is simply to not use the
            same variety in a tight rotation - we do
            not make recommendations as to what to
            varieties to rotate.
            Hope this is clear. Thanks for getting a
            good discussion rolling.
            Clint Jurke
              Ado's post demonstrated the usual answer and message. I understood the recommendation was to rotate between companies and not varieties.
                wd9,
                The CCC is quite clear about rotating
                varieties in tight rotations. I am quite
                certain we have not advocated rotating
                between companies - there is no certain
                benefit to doing this since seed co's
                can use the same source of resistance in
                their germplasm. Perhaps there is a
                misunderstanding.
                For more background on the subject, go
                to:
                http://www.canolawatch.org/2011/04/26/bl
                ackleg-risk-rises-with-tight-rotations/
                Clint
                  While i appreciate your clarity, i am not the one with the clarity issue.
                  This spring i spoke to a fellow farmer who was quite convinced that after a presentation he was to switch companies as a blackleg management strategy rather than varieties. It is also coming from consultants who received the same information. Bad info needs to be cut off.
                  I posted this message not to be told repeatedly on blackleg strategy (I totally get this) but rather to make an awareness that there is confusion in the market regarding strategies such as HT system or company or variety.
                  You have been quite clear in your posts about the strategy here in the anonymous agriville world, the perception and messages however in the real world seem inconsistent.
                  If information is put into the marketplace it should be clear as you have posted above from all members. While i usually am one, I'm not that much of a sh*t disturber without doing my homework first.
                  I am however a strong advocate of this industry, always have been, always will be and i will challenge any statements to ensure what is being said is true if i hear the contrary as in this post. In the process, usually piss off a bunch of people, but generally we end up with a better industry.
                  Is this clear?
                    Thanks for clearing that up wd9. So, just to
                    make sure I understand, you asked in your
                    first post why council would make an
                    recommendation that wasn't right. Ado's
                    response confirmed that the recommendation
                    you had heard was out there. CCC agronomist
                    Clint confirmed that council has not been
                    making that recommendation. However, the
                    incorrect information is still out there.
                    So, the CCC agronomists will have to be
                    clearer when talking to farmers and other
                    extension people about this in the upcoming
                    winter extension season.
                    Wd9, I hope you will be attending one of the
                    meetings the CCC agronomists will be at this
                    winter to ensure this happens.
                    Ward Toma
                    General Manager
                    ACPC
