1 first time clearfeid canola grower on pea stubble.
looking for best spray recipie
this first feild had 1/4 rate pursuit3/4 rate select last year in peas, it was clean last fall . this year canola with
lots of wild oats and very little broad leaves
2 and two other qtr.s of peas on wht. stubble ,sandy land , were burnt off (glyphosate)just before the peas came thru. expecting small kochia , russian thistle,wheat &wild oats.
odyssey came with canola package so i gotta use it somewhere.
have been using 1/2 rate pursuit and 60 acre select with rest of peas
should i put the odyssey on the peas and a light pursuit 1/4 - 1/3 with full rate select on the canola?
good stands of peas and canola
peas are thick 3-5 fingers high and canola is 3-4 fingers wide
not too worried about rotation as all acres will be wheat next year.
any other combos you have used or might suggest.
any thoughts on controlling the kochia in peas ,if it comes, whats better pursuit, odyssey, MCPA K
