With all the chatter about foliar nutrition I figured I would post some facts to help anyone along with decisions.
The following nutrients are always plant mobile: N-P-K
The following are always plant immobile: Ca, B
The following are mostly plant immobile: S, Cl, Cu, Zn, Mg, Fe
Folliar efficiencies when compared to soil applied according to Uni. of Cal Davis.
N = 5-10:1, P= 20:1, K= 27:1, S= 5-7:1, Zn = 12:1, Fe= 100:1, Mn = 30:1, Mg= 75:1, B= 5:1
Some other things to watch for include
Leaf absorbtion- triazone>nitrate>urea>ammonium
Translocation & Remobilization-
Triazon>ammonium>urea>nitrate
Aslo keep an eye on the salt index and osmolality (how much a product will pull water out of a plant) the lower the number the better because of less leaf burn. Solubility will also give indication on how plant available a product will be.
Lastly, micros and P carriend on humic, fluvic or carboxylic acid will be absorbed much better by plants and stay available in the soil longer than straight EDTA chelates.
One last thing to be aware of is that quite often low quality fertilizers, soil or foliar, contain high levels of heavy metals and other toxic compounds. So sometimes you get alot more than you pay for.
Hope this helps, it's just a coles notes version based on the info I have accumulated, so I would talk to a pro for more info.
