Looking at chips for 02 dodge like the edge juice wondering if anyone has any experience. Thanks
Chip for 02 dodge
Tags: None
Have a couple buddies with 04-06 Dodges that are running Diablo tuners. Not as handy as others as you have to stop the truck, pull a couple fuses and change the tune BUT none have changed the tune yet. Depending on the truck and driver they are getting 22 -31 mpg (witnessed and hand calculated). The 05's get the best, no other mods. The 2 guys that tried Edge units swapped them for Bully-Dog and Diablo. These guys are after MPG not power/show.
Bought one for my 05 gas suburban, lost 2 mpg but big power and shift response, I want mpg so am gonna return it for one for Dads 05 Cummins.
$425-450. Available at almost any performance/after market accessory dealer.
Comes preloaded with 2 to 4 tunes (software programs for your engine and trans if you have an auto) 40 to 200 hp increase depending on which one you load. I think the 120hp one (not sure)gives the biggest MPG increase.
Truck shut off, pull a couple fuses, plug controller into OBDII port under dash, turn on key, hit a couple buttons to save factory program and load desired tune, turn off key, replace fuses and try it.
I will check and see for sure which tune they are using for MPG. These aren't kids from the oilpatch with jacked up trucks running 40" mudders, they are 35 -65 year old guys pulling the odd 5th wheel camper or skid steer on a car hauler. Lots of empty running at 110-120 KM. Witnessed 33MPG in October(-5*C on COOP summer fuel) running empty at 125KPH. Hand calculated filled at the pumps, return trip on ESSO was 25 and truck idled poorly. Same guy getting 28 now with winter fuel. His truck likes COOP or Petro-Can. ESSO and Shell don't agree with it.
There are custom tunes you can download for different situations or have a custom one written for you. The preloaded ones work for 99% of the guys.
I might check for a custom tune for my Suburban that is written just for increased MPG. If i can't find something i will return it for a unit for dad's 05 cummins.
