If I build two 33 ft diameter bins should I put the unloads and doors facing each other or straight out the front of the bins?
Self unloads on flat bottom bins
Really. thanks for replying. I may have made a mistake then. cause I bought a stair case for two bins and they say that the inside latters need to bd to be over the doors. that won't be the case if i put them in front. i don't see why the inside latters need to be over the door. is that necessary?
Our unloaders and doors are straight out the front. Our ladder starts at the back and comes around between the 2 bins. Our fans are offset from the back at the 1 O'Clock position. This is a no brainer but the inside ladders are at the top of the outside ladder. Just a suggestion but heaters may be a good addition and static pressure gauges.
