Changing boots on Morris drill?
    Any suggestions for replacing Morris Paired Row Boots on 12" spacings w/ edge-on shanks? Likely to move to side band style, what brands to look at that can stand some rock? NOT looking for disk openers.
    the new Universal opener system from Dutch is great on every drill, including the Morris Edge On. It gives you the flexibility to go to a side band if that is what you want, and with just changing the tip, the ability to go back to a paired row without changing the opener body. If you would like more info, go to dutchopeners.com and check them out! Or, message me back and I can give you more information.
      thanks, will check them out.
        broker, do you know how wide the knife portion(cutting 3/8 or 3/4" deep) would be on a 2 1/2 or 3 1/2 paired row opener? Would it be 3/4" or 1" ???
          sorry for the extreme delay in responding...the tip portion of the opener on them is 3/4" wide...hope this helps
