calibrating hoe drills
    I have a old set of IHC 150 hoe drills that I want to seed canola with this year. Anybody know the proper way to calibrate them?
    You could try going to the alberta ag site (agric.gov.ab.ca) and click on calculators in the yellow left hand column, then scroll down to the bottom of the right hand column and pick yur crop. After you enter your data and press calculate, it will tell you how much seed should come from each run over a certain distance.
