Stuck drill
    Stuck drill
    What are people's strategies for getting a BG 5710 or similar drill unstuck? There's only one tractor available unless the boss asks a neighbour. I've been using a two rope to walk the machine but those gang packers are just ploughing. My next step is to pick away at the mud in those packers by hand so they can start rolling instead of pushing.
    Unhook, get out tow rope and hook it up
    so the tractor is pulling it at an angle
    and on dry land, then take a run at it.
    If I am lucky I can get it out in one
    shot, sometimes it takes a couple go's
    at it from different angles to get it
    out. If i run i can be going again in
    20-25 minutes 15 minutes with two
    people. We use a huge tow rope 75 feet
    long that is a bitch to handle but is
    stretches a lot and works great. I rap
    the tow rope around the clearance marker
    s and that is the biggest job getting it
    off and on.
    We also took off the steel packers and
    put on the 2 1/2 rubber capped packers,
    that seemed to help a lot. I think
    bigger tires on the front would help on
    the front as well.
      My experience is when spinning out and not moving stop immedieatelly. Unhook and strap on a 20 fooot strap on, if you spin out too much you could be ****ed. Best to be not stuck than strap onned.
        if a cat with a winch is handy, no problem. unhook, have cat back up to tool bar and winch it upwards, you can then hook up a tow rope with tractor if required to help out, especially if the cat is only a D6 or so. I've pulled seeders out of pretty hellish holes in this matter.
