Has anybody used these? Whats the best type? What width of openner are you using?
shank mounted packers
I have used K-Hart for 3 years with satisfactory results; I have a Case 8100 which is a Morris 8900 with 12" spacing and 1" knives. I deepband fertilizer in the fall (without the packers) and seed in the spring with the packers. I am in heavy clay (Regina ) and therefore use the narrow packer (2"). If soil moisture (surface) is high I am prepared to wait an hour to avoid buildup. The seeding results are comparable to any airdrill.
