US OSHA "how to perform sweep auger operations" 10 rules:
    Bin sweep rules in US:
    "Ten Sweep Auger Safety Principles
    Below is the list of Sweep Auger Safety Principles that
    OSHA, at the National Office level, has agreed to, and
    which should now serve at least as “guidance” to the
    industry for how to perform sweep auger operations in
    compliance with the Grain Standard:
    1. In accordance with 29 CFR 1910.272, no employee
    shall enter a grain bin until after completion of a bin
    entry permit, which confirms there are no engulfment
    and/or atmospheric hazards present inside the storage
    bin, or unless the employer or the employer’s
    representative who would otherwise authorize the
    permit remains present during the entire entry. The
    grain bin hazard evaluation shall be completed by a
    qualified person.
    2. Before entering the bin to set up or dig out the
    sweep auger, the subfloor auger and the grain entry
    points must be de-energized and locked out.
    3. Before operating the sweep auger, the grate/guard
    on the sub-floor auger must be in place and secured.
    Employees operating the sweep auger cannot walk on
    the grain, if the depth of the grain presents
    engulfment hazard.
    4. It shall require that the sweep auger is provided with
    guards and covers per the manufacturers’ design, and
    the only unguarded portion of the sweep auger is the
    point of operation.
    5. A rescue trained and equipped observer, in
    accordance with 1910.272(g), must always be
    positioned outside the storage bin monitoring the
    activities of all workers inside the bin.
    6. If a worker is to enter the bin while the sweep auger
    is energized, the employer must utilize engineering
    controls within the grain bin to prevent workers from
    coming into contact with the energized sweep auger.
    7. The use of only administrative controls without the
    use of an engineering control is not a sufficient means
    of worker protection. Acceptable engineering controls
    may include:
    Sweep auger equipped with an attached guard which
    prevents the workers contact with the unguarded
    portion of the auger in accordance with 1910 subpart
    O.;
    Sweep auger equipped with a control mechanism, such
    as a dead-man switch or other similar device, which
    will allow for the sweep auger’s operation only when
    the operator is in contact with device. If this method
    is utilized as a means of worker protection, the worker
    must be positioned at least seven feet from the auger
    at all times it is energized; moreover, if worker(s) in
    addition to the operator of the sweep auger are in the
    bin, additional engineering controls (such as those
    described in section 7 of this criteria) must be used to
    protect those worker(s).;and
    Portable guardrails are permissible, provided they are
    placed at least seven feet behind the sweep auger.
    Note: the use of a warning line, or other easily
    removable device, other than a portable guardrail, is
    not considered sufficient engineering controls.
    8. The auger must be provided with a positive speed
    control mechanism or bin stop device that prevents the
    uncontrolled rotation of the sweep auger.
    9. Workers are prohibited from using their hands, legs
    other similar means to manipulate the sweep auger
    while it is operating.
    10. If maintenance/adjustments are necessary to the
    sweep auger, the sweep must be unplugged, with the
    person making the adjustments maintaining the
    control of the plug, or locked-out in accordance with
    lock-out/tag-out procedures."
    http://www.oshalawupdate.com/2013/01/24/breakin
    g-news-sweeping-changes-to-oshas-sweep-auger-
    enforcement/
    is the link
    • Happytrails
      • Dec 2009
      • 832
      Boils down to "nobody works, nobody get hurt". Unfortunately famine is next.
        Common sense... a lost skill... Now we need all
        hoppers?
        I agree a person needs to be outside the bin....
          • 9408
          intended for commercial apps. but
          applicable to all.
          Doesn't all that ink on paper make
          everyone just glow with satisfaction and
          safety. Anyone who's sat thru training
          sessions today gets the overwhelming
          feeling that it's nothing more than
          corporate level CYA!
          Youtube Mike Rowe. His dignity of
          work ( lamb testicles ) vid is excellent
          and to the point.
          • seedsman
            • Nov 2004
            • 119
            We grow hybrid canola for Bayer in southern Alberta. They follow similar protocol. I have to sign a waiver before I can enter my own bin to run my own sweep. The Bayer guy sits in his truck and watches for the entire duration. He is not allowed into the bin, unless he needs to rescue me. If my system wasn't electric, he would regularily be monitoring the air quality in the bin to be sure there weren't any exhaust fumes in the bin.
