Macdon M150 Light issues.
    • 17489
    On this swather(08 first production year) we are having light issues. We don't do alot of night swathing so it hasn't driven us completely nuts yet but...(only about 600 hrs on the machine)
    When working at night, with all the lights on, a circuit breaker will trip.
    The newer models have a heavier circuit breaker in place for the road lights(30 instead of 20 amp) and two heavier maxi fuses(larger fuses for work lamps) but we never blew the 20 amp maxi fuses in the first place. The circuit breakers were ever the only things that would trip and reset when the complete load was taken off of them or reduced the load.
    There has been an update in the newer models of M150 on the fuse/relay/circuit breaker panel compared to ours. The ones I listed and a "lighting direction relay" which isn't on ours.
    We are able to swath at night by reducing the load on the circuit breakers. We are basically down to the cab forward lights(working lights facing forward) We shut off the rear(roading lights) and unplug the two lights on the cab corners shining to the ends of the header and remove the detachable radio front.
    Anyone else having any issues and what solution did you find. Macdon Customer service hasn't been any help (by not returning email inquiries)
    We clean this thing off that a mouse would starve if it had to live on it and put it in a shed(tractor portion) and put poison on it as well. There is no signs of chewing or smell of mice. I think it may be the load for the gauge of wire is too high. Nothing was added to it that would increase the load on the wiring. Does anyone know of an upgrade from Macdon?
  • mcfarms
    • Nov 2004
    • 1703
    Have u asked this in the combine forum here it might turn into a political ,religious or wheat board discussion.
    Have you asked your friendly neighbour dealer for your territory reps phone number?
      It wouldn't be hard to hook in a relay triggered by the light circuits but getting power direct from battery.
      A little 2 wire 12 gage with relay plug.. 50 $ could get the source power changed over. 30 amp relays are cheap.... As are 30 amp breakers. Peavy Mart has good cheap wire... Get some loom and Cover and tuck in new power supply wires. Upgrade better than MacDon.
        Sorry MC... Was writing on cell while you posted.
        Hope I wasn't too political or religious talking about : relays, breakers, 2wire... Loom and Peavy Mart!!!
        Cheers!
          On new JD equip the Canbus makes us do these mods often... To not mess up ecm and computer. Amps are spec driven now.... If anything is unusual the ecm gets mad fast.
          • mcfarms
            • Nov 2004
            • 1703
            Yes Tom it was awful but but this time Ill let it slide. A good idea though whay about changing the lights out to LEDS less power draw and nicer light been going to do that on our m150, we got a new peavy mart. Going to be hard on the Poor Ol UFA.
              • 17489
              mcfarms, I'm not a contributor to the combine forum and a lot would argue here either, lol.
              Have you had this issue?
              Sounds like a pricey conversion.
                • 17489
                I saw some newer style M155's and I think they still have the old style lights as well.
                  • 9964
                  Ours is the first year, 2007, NO issues at all at 1100 header hours. Tell me it was hand assembled as a pre- production.
                  Heard of our electrical issues though.
                  • Jay-mo
                    • 734
                    I have fought the same issue.
                    Here's the fix:
                    Take the cover off your fuse box beneath the right hand step platform.
                    Now go swath all night, problem free.
                    Yes, it will get covered in dust.
                    I have replaced all the relay/fuses with higher amperage ones and it makes no difference. (That was the official fix from Macdon) From what I hear I still don't think Macdon has truly fixed this problem.
