How to use CORN GRINDING MILL correctly? First of all, we need to learn about corn grinding mill structure and features. Corn grinding mill depends on one pair of opposite differential rotation to peel materials, extracting the endosperm and milling it into flour.
Corn grinding mill has sealed and duplex structure, electrostatic coating surface, luxurious and beautiful appearance. It has pneumatic auto-control, which is easy to operate. It also realizes remote and centralized control and frequency conversion; It is internally installed with negative air suction device to improve charging and decrease temperature between roller and materials.
Corn grinding mill operation matters a lot. Correct corn grinding mill operation can prolong its service life. First, we should keep familiar with the grinding ring service life. The rest minimum wall thickness should not be less than 10mm.
Second, during material grinding, we should observe this process and strictly prohibit metal mixed into the machine, which may damage the grinding roll, the grinding ring and the center hanging bracket.
Third, convey the material evenly to the stock bin, as too much material may cause air duct blocking and yield reduction.
Fourth, we can improve the working efficiency of the corn grinding mill by adjusting the air blower according to the fineness and yield requirement.
Fifth, provide good lubrication condition for the rolling bearing of the transmission part to avoid serious damage.
For more knowledge about corn grinding mill, please visit our website.
Corn grinding mill cannot be put into use after its installation. CORN GRINDING MILL ADJUSTMENT is necessary. Corn grinding mill adjustment starts from grinding roll, which is also the most important part of a corn grinding mill. The distance between tow rollers of the corn grinding mill can decide the fineness of the corn flour or grits. Therefore, the roller distance adjustment is quite important.
Corn grinding mill adjustment can prolong its service life. There has a complete processing section for the corn processing. It can help us work better to master such a processing section. We should adjust the eccentric bushing besides of the sphere screw and then fasten the fixed eccentric bushing. We can put the feeler gauge between the two rollers and adjust the distance to the best condition.
In corn processing euipment adjustment, we should pay attentino to the following aspects:
Before corn grinding mill adjustment, we can prepare all of the corn processing assistive devices and vessels.
Check the tightness degree of the conveying belt.
Before working, we can let the corn grinding mill have an idle running for 15 minutes so as to detect the actual quality of the corn grinding mill.
http://www.corn-milling-machine.com
