attention case combine owners
    ran into a strange thing on our 2008 , 8010 yesterday . was idling in yard and main fuel line from electric pump to ecm started blowing fuel all over everything . it had rubbed through where it comes up behind fuel tank right by bottom corner of rad . rad fan blew it all over machine and motor . hose is made out of light rotten shit . if it would of done it combining wheat I'm sure you would of saw another case combine fire . to install a new hose I think you might have to pull fuel tank off ? made a new longer one out of hydraulic hose and ran it in a much safer place . this should be a safety recall ???? someone on here once wondered why so many case combines burn ? maybe this is the answer ? once they're burnt how would you know ? CHECK your fuel lines , please. feel how soft and shitty and rotten it is , look for rubbing beside corner of rad .
    Thanks
    Although somewhat different our NH of the same vintage may very well have the same cheap fuel line.
      Was combining with an 8120 which had its fuel line burst as well. Fortunately it was noticed, shut down and repaired before things got out of control.
        A friend had his 8010 burn last fall. Grain cart operator pulled up to dump. When combine was unloaded, cart stopped he saw some smoke coming from the engine area and by the time he radioed the combine operator the back end was engulfed with flames.
        No one got hurt but that thing burned fast by all accounts. Wouldn't surprise me if it was the bad fuel line.
          If it was fuel problem in a car there would be recall. Insurance pays for poor engineering and our premiums just keep going up to cover costs. Case gets to sell new combines.
            Cheapest supplier gets the contract, anywhere on earth... all colors all types of iron. Macdon had shit hyd hoses in 2010, replaced ALL.
              NAPA sells a fuel resistant fuel line for $2-3 per foot. Price will vary depending on I.D. of fuel line......if you buy fuel line from Case dealer multiply cost by 10.😂
              Regular hydraulic hose will eventually break down if used for diesel fuel....at least that's what I've been told.
                ajl , I'm going to check the 8120 tommorow . probably same shit line ?
                  I will have lots of time with another 1.2 inches rain today , passed the 2 1/2 foot mark heading for 3 ft of rain I guess ? 3 yrs rain in one growing season
                    Wrong kind of rubber, better change it again...
