We use a Bourgault QDA Paralink. It doesn't seem to like tall flax stubble, even dry can cause problems but tough is worse. Long pea vines are another issue...not bad when they're dry but impossible tough. It clears most other stubble quite well, even anchored lodged cereals if it's not too tough. I don't believe in the "scorched earth" theory or blanket tilling (even vertical) whole fields...lots of spots don't need it, then it turns into a patch work of guessing where to till and not. I don't know if there is an independent shank drill out there that is perfect. I miss the simplicity of the flexicoil style drill we had before this one but like the seed placement of this one. Straw management is key-duh! But other than cutting the flax crop.much shorter what other option is there...clench your teeth and bare it!
Equipment Design...
Tags: None
Speaking of limitations. ...anyone getting any spraying done? But I guess the solenoid tips can spray in any conditions.
Guest
we still use a morris maxim 2 , it has edge on shanks . this shank design that goes straight down is one of the best straw clearing units we have ever had . we had a maxim before with C shanks and it was useless in straw . I watch all these independent drills , morris included , battling straw and just shake my head ! we have a bourgault 9400 deep tiller and an 8800 cultivator , neither will come close to the drill for straw clearance. and it's worth about 10% of what an independent drill would cost
Agstar..with depreciation probably not!
Case. The paralink shanks are also straight up and down but of course each trailed by a little packer wheel. Then in front of everything the infamous mid row banders. Lots of stuff under that drill. Gang packers can be tough(drag) in muddy conditions and not pack uniform across the individual gang, especially if it's a wider one.
Guest
Regarding mid row Banders....has there ever been a more high maintenance thing ever invented? How can a bearing that turns so slow pile up so often? I hate mrb's with a passion but they do put down the 46-0-0 very efficiently. Really though come on bourgault there has to be a better way. Also the paralink drill is an excellent unit.Last edited by sk_wheatking; May 7, 2017, 08:34.
If conditions are bad nothing is going to work in flax stubble.
Most years we seed into chopped flax straw residue with minimal problems when conditions are right
Last year the stuff grew over 30 inches high. Had to burn.
Case...we had a 40ft NH440(flexicoil) before the one we have now...only three sections and the wings were a little too long for some of our rolling topography we have...even though it was designed to flex (twist) I thought it was too rigid for that length of section, I think they were about 14 ft.
Will there ever be a perfect mousetrap?
101.. . When we had old 850MF combines and the straw made one trip through the cylinder and danced it's way down the walkers to the factory chopper and fell evenly across it, it did a decent job of "chopping" and.spreading the flax straw. Now with the Agco rotary combine we have it gets twisted into lumps and falls to one side of the MAV chopper and is really hard on it's drive belts....so we drop, bunch and burn...even though I don't like it.
