Planter / drill
    • 22463
    Planter / drill
    Quite the difference now .. seeded same day ...
    45CS40 with Horsch planter at 2 lbs
    45CS40 with Bourgault drill at 4.7 lbs
    Granted our Bourgault is not a paralink though .
    • 9398
    There is no doubt. Planters are the future.
      • 4018
      Thanks for the pictures. Confirms the conclusion I came to last night. One neighbor calls abd I go look at his canola with him. Everywhere the tractor, cart and anhydrous tank went nice germ can see the rows perfectly. Everywhere else not so good. He rolls his canola after he seeds and uses a flexi 5000 with Dutch low draft 3.5 inch spread. Second neighbor talked to him a few days ago. Flexi 3 compartment tank same opener. Puts canola in one tank, 11-52 in one tank, urea-potash-sulfur blend in other. Puts 11-52 with seed and blend in single row between the split seed rows. Pissed right off at how poorly his canola is coming up. Anyway long story short, my thought last night was we would be farther ahead to buy a planter between the 3 of us just for canola. Your pictures tell the tale.
        furrow , don't know anything about them , are they really expensive ? work for all crops ?
          nice crops !
            • 22463
            I am just relieved it turned out . We were nervous to do a 1000 ac test so to speak.
            This is the wheat stubble today ..
            And again side by side with our Bourgault
              • 22463
              Two ways to look at expensive...
              ya they are not cheap , $300,000 plus
              But they can do 35-40ac / hr . And do it right .
              So a 75-80 ft drill would be about $600,000 to $700,000 now ?
              About the same efficiency as far as ac / hr
              Just got to think a little different on fertility
                • 4018
                Furrow can you apply all your fertilizer and seed all in one pass? With most corn planters you have to make a separate pass to band on fertilizer.
                  • 22463
                  I streamed on the N with sprayer before seeding . And applied the S with the round up in pre burn .
                  This planter has 800 gal phos tank on board to get phos in seed row just below seed
                    • 22463
                    We used it for soybeans, canola and corn
                    15 in space on the beans and canola
                    30 in space for the corn
