I have a submersible water pump in a steel crib and pump is stock 70 feet dowm. Does anyone have a solution.
water well
A few years back I had a similar problem. If you can find someone who has a cable drilling rig they should be able to pull it out using a fishing tool. This consists of a piece of pipe with barbs cut in it. They slam the tool over the submersible and it usually catches. Very similar to a fishing tool used in the oil patch to recover lost bits.
