Wheat timing .... spraying
    Going back to S/f post on spraying wheat on the green side and a local wana be bto with the same opinion on how the rest of us don't know how plants grow .... lol
    Well , I did an experiment.
    Sprayed when I normally do , not near as green as that , on a 1/2 section . We started seeding the 1/2 section got half done then had a 4 day delay with rain in early May . So spraying I did the outside rounds which were split also 4 days at seeding . I sprayed the earlier side and seen the definite difference in maturity. Waited 4 days and finished spraying when it matured more .
    Combined the rest today and did the outside rounds on the later seeded stuff .
    Well , 10 bus we lost on that outside 200 ft . I knew it was on the green side when I did it but thought time will tell. It did . It was not as green as S/f posted or what the local wana be bto did at all.
    So yes it makes a huge difference to spray on the greenish side .
    Still a #1 but not near as nice as proper labeled timing of round up which we normally do .
    Anyway , just thought I would share
    When we do yield maps I will post them.
    I guess some can give yield away just to get er done ...
    there is a reason why the timing is on the labels btw.
    Sorry S/f not picking on you but your wrong on what you think or been told .
    I think all you greediest that use roundup as a desiccant so you can get over more acres, and buy more green combines to enflate your egos should be required to have a dose of roundup in your coffee every morning.Sooner or later the consumer is going to demand an end to it.
      Thanks Furrow, knew that but same as locals cutting canola with out proper color change ...you give up yield for hurry up. A cost to cutting corners, off label use.
        Well horse when we get paid for not spraying round up I will have no issue swathing again whatsoever or leave it till dry on its own .
        If there becomes a premium for non sprayed wheat , or a discount for spraying it I will change no problem with that at all.
        All the hype on this issue needs to translate into reality.
        Make it worth while not to do it when done properly. It obvious farmers only hurt themselves by spraying to early but spraying by label 99% of the time is still an overall benefit to quality and productivity on farms .
        Green combines not allowed on this farm lol
          I hear circus theme music in my head when I think about how we farm.
              Furrow i said 80% of the field was at the proper colour and the 20% needed to be pushed and actually it was way riper than the picture looked. When you opened the seed up the seed was already at the stage you could just put a dint with finger nail. Thats ready to spray.
              Yea the comment on not spraying vs spraying and swathing to green vs waiting. When they pay extra for non sprayed wheat ill buy more swathers and play that game. One local on malt barley sprays and here is his results 1 in 5 he gets accepted. Vs the rest 4 in five for malt. You put on bag if sprayed or not. Oats some mills don't want it some mills take it. But i bet if the crop was so small and nothing was available they would take it.
              Yes spraying at correct time is critical. Im still spraying wheat as last two sections are just at perfect time.
              We always on Canola start some fields a little on the early side so we can get to the end of Canola swathing just as its almost to late to swath. We'll that has been changed now with strait cut varieties. Last 6 quarters are Strait cut and like since they came out years ago its keep the swather and swath at 95% colour change. No more starting early to sacrifice those fields so can get over all the fields.
              Sell the swather what a funny option.
                Ok gotcha , I hear what you are saying now lol
                I do about the same 80-90% ready and giver .
                I agree with the swather thing , I would not hesitate to go buy anouther used swather to cut the wheat down if warranted
                  I agree if they want wheat that is prone to sprouts from lying on the ground ill swath in front of the combine again. In our area and yours you cant wait till its totally ready like Assinaboia etc. We don't have natural desiccation where the plants just shuts down and its ready to go. When RR came in it took our farm to a whole new level. Easy harvest Good grade even crop maturity and no spoilage from green kernels. Oh how i hated strait cutting back then.
                  Also we were harvesting in October in most years with that method.
                  So sell the swather ha ill buy a few more if thats whats coming.
                    Funny you say that, I often hear the same circus music when I think about how I farm! This must be some kind of common thought proces when farming does not go as planned, which it never does. The greater the deviation from the original plan, the louder and faster the circus music.
                    Furrow is correct, follow label instructions. Every has to make their living the way they know how. If you want to spray once or 10 times is entirely up to the farmer. Just keep spraying to control the weeds. Some of the lentil crops around here sure could have used a couple extra passes of spray. They should be asking long term lentil growers what they use. My older farm helper asked me to slow down so we could figure out what crop was in the field. Usually a person can identify a lentil crop. There is going to be kochia, wild oats, hawks beard and sow thistle for generations on those fields. Im curious about yeild reduction from competition. Probably a non issue. It is incredible, they make the organic guys look like complete amateurs. It must pay well because their weed bank just got a big deposit.
