Tired of the covid debate so here goes. Looking at updating my combine. Presently have a CR 9070, this combine works well and has treated me well. The problem is there aren’t very many New Holland’s available with the options I want, hours I want. I would like the stone roll, short feeder house so late model 2014 or newer and less than 1000 threshing hours. Seems to be more Case and John Deere’s available with less than 1000 threshing hours and priced under $300000. Just wondering everyone’s opinion on Case in 8230-8240 vs 9230-9240 vs John Deere S680 vs Cr8.90?! Thanks
Combine question
You can choose any model of harvester - they are all great. Only you need to individually assess your needs and, taking this into account, choose the model and configuration of the combine.
My experience only with 8120s and 9240.
8120 notorious under powered. Most were chipped, some with bad results. Even 30s chipped, DO do your research!
9240 awesome. Preferences if can would be options like folding tank, diff lock, and cruise control. I have the 120 blade chopper.
The 40s have resolved the engine air issues like rad and air filter.
Fuel and def consumption not bad for work done.
Twin rotors likely more consistent in hard thresh wheat. But no reverser.
Rotor style and configuration in Red can be a either or decision, no clear winner.
We only grow wheat, barley, peas, canola.
Originally posted by blackpowder View PostMy experience only with 8120s and 9240.
We only grow wheat, barley, peas, canola.Last edited by Hamloc; May 1, 2021, 07:43.
Have no personal experience with the 12.3. The 10.9 was not enough. The 15 is noticeable. Cubes to hold at 80-85 smoothly. NOT planning any mods unless def gives grief in future. No replacement for displacement.
You should be fine. Just do your homework on engine mod. Some are likely fine. Others are not.
Actual reprogramming seems? to be the way to go rather than fooling sensors.
The Steinbauer I put on my 10.9 was a disaster, my neighbor as well.
Originally posted by Hamloc View PostTired of the covid debate so here goes. Looking at updating my combine. Presently have a CR 9070, this combine works well and has treated me well. The problem is there aren’t very many New Holland’s available with the options I want, hours I want. I would like the stone roll, short feeder house so late model 2014 or newer and less than 1000 threshing hours. Seems to be more Case and John Deere’s available with less than 1000 threshing hours and priced under $300000. Just wondering everyone’s opinion on Case in 8230-8240 vs 9230-9240 vs John Deere S680 vs Cr8.90?! Thanks
I got mine from https://deerequipment.com/ C & B Operations , and they have been really excellent at helping me with any modifications or parts I need. I would recommend checking them out.
I think that you can try to buy a new one. I understand the new machines are too expensive for your budget. A great solution would be to buy a used one. You can purchase https://www.kitmondo.com/ used machinery at any time, even before they are sold. The main reason is that you can often get a better deal on the machines than you would get through normal channels. This is especially true if you are buying appliances for use in your own business. I purchased from them a few things two years ago, and I am delighted with them.Last edited by esterfell; Jul 15, 2021, 01:14.
