Am considering buying a GPS system for spraying and seeding. Would appreciate any feedback on which ones are good and which ones to stay away from. Thanx in advance for any feedback.
GPS systems
Other than slight innacuracy on sidehills,there's nothing wrong with the outback.I bought one last year and it worked great for me.
My concern has more to do with whether the company will be around for very long or not. They are essentialy built by CSI out of Calgary, and CSI has been losing money for quite a while. So my concern would be, are you going to be buying a unit that has a dead end future.
Depends how accurate you want to be. I bought a Trimble light bar a year ago and used it for some spraying, harrowing, rolling, starting fields parallel to the road, etc. I found it tiring watching lights all day, compared to the markers I have on my air drill.
With the light bar, the tractor is already 6-8 inches off the mark before it shows on the lights. By the time I see it, I may be off 8-10 inches. By the time I react, and turn the wheel, I'm 10-12 inches off the mark. Then I correct, probably over correct, and before I know it, I'm 6 inches off on the other side. This is more of a problem if the field is not smooth.
I just took delivery of my Timble EZ-Steer system today. With the EZ-Steer demo we did, I almost never saw 1 of the lights come on to show that I was off the mark.
Adding the EZ-Steer barely doubles the price, but I think you get much more bang for the buck with the steering system than you do with a visual guidance system. It should double your accuracy as well as eliminate the stress of steering.
As for your lights not telling you soon enough, it is because you do not have the look ahead set high enough. You are are travelling up to 6mph you should have a 1 sec look ahead if you go up to 15mph you should have a 2sec look ahead and if you go any faster you should have a 3 sec look ahead. What this does is tells you where you are going to be, not where you are, which is the important part anyway.
If I'm traveling 6 mph on a field that is not smooth, and the lights set at 3 inches, and the look ahead set for whatever it should be, the lights just move around too much for my comfort. This is especially true for the tall 2 wheel drive tractor with single tires set at narrow row spacing that I do most of my spraying with.
The Outback display may be easier to follow, since it has the "look ahead" lights as well. However, the last time I checked with the Outback dealer, he said they were not working on anything except units using the WAAS signal. So if WAAS isn't accurate enough, or drifts too much for your liking, you can't upgrade to a better signal like you can with JD or Trimble (and maybe some others)
