In reply to pulseman, you said do your research before buying, if you don't know what the trimble does I guess you didn't do your research. As to position of the receiver: with EZ-Steer on an articulated it is recommended over the front axle as this is the only point that does not swing. If you are just using light bar guidance, front of cab or the nose of the tractor works well. If you are using an Accutrak autosteer put it on the nose of the tractor.
GPS systems
