seedmaster drill
    seedmaster drill
    Anybody out there using a seedmaster drill? If so what do you like/dislike about it and how does the smart hitch work? Does it have enough flex front to back, it looks so deep for going through draws that it would pull out of the ground. Any experience with their tank? Thanks
    First put a flexicoil or bourgault tank in front.
    Don't worry it will go through the dips just fine.
    But they have made lots of improvements over the years go look at used ones on the lots and check out weak points.
    If it is extremely wet can build up and then throw depth out of whack.
