Setting cylinder speed on JD 7700
    The cylinder speed adjuster operated from inside the cab is chain driven at the sheaves. Last year we had numerous instances of the chain jumping the
    wood tightener. We made adjusting a two man operation, one to adjust and
    one to watch the chain.
    Prior to this harvest the adjuster sprocket was replaced and shimmed.
    Although much improved, the problem still exists. Is there an easy solution to this problem or is there a way to upgrade this system?
    It is hard to say what the problem might be without looking at the machine. The first thing to do is try figure out what causes the chain to jump off - possibly sprockets are misaligned, or the wooden block on the tightener is worn, or the chain is catching on something. If it is a problem with the wooden block, you might want to try replacing it with a HDPE plastic block (high-density polyethylene).
    For information on possible updates to this machine, check with your local John Deere dealer. You might also want to contact the PAMI (Prairie Agricultural Machinery Institute) station in Humboldt, SK, where they perform combine evaluations. Their phone number is (306) 682-5033.
