Alberta’s drought shaping up to be ‘worse than we saw in the 1920s, 1930s’
    [url]https://nationalpost.com/feature/alberta-drought-worse-than-the-1920s-1930s[/url]
    From the National Post. It must be bad if the paper that almost never mentions climate change is covering the persistent drought.
    Growing season 2024 is shaping up to be the wettest drought I've ever seen.
    So if the current drought is caused by climate change, what do you suppose caused the drought of almost a century ago?
      I haven't checked the Alberta precipitation record for spring 2024. How much rain and snow has all the province gotten? North to south and don't leave out a report from the drier areas.
      So is the drought over officially over and the last several years just a distant memory that never really happened?
        Hmmmm , now for the rest of the story …. Again
          Then this is the most recent soil moisture maps , huge reversal over the past three weeks except for the far NW
            So you haven’t watched the Alberta precipitation the past three weeks but post hugely outdated information to justify your climate change mantra of heat , drought , fires ????, and climate disaster propaganda
            give up already , it’s embarrassing
            look at current situations
              I recall someone recently asking you how long you have been living under a rock.
              So you were ignorant of the fact that the driest parts of Alberta have been suffering from too much precipitation this spring.
              ??????And yesterday you displayed your gross ignorance of the current state of the electric vehicle market which is entering panicked contraction mode
                So the Peace is still in drought. But you didn't mention that?
                And there is still some drought between Edmonton and Calgary.
                And this spring makes up for all the previous dry years? Its all good? The grass is a foot high and the cows are all back?
                  Keep posting chuck , gives perspective of you overly exaggerated the climate change propaganda is being laid to waste
                    Only in your feeble mind Furrow!
