Last year we purchased a new RBX 562 case baler. It has been a problem ever since it came. Here is the list.
1. Belts weren't tracking properly..
answer: install an expellar roller
and various other rollers
because they weren't round
2. Material packing in between the
rollers and the sheet metal causing
friction and heat..
answer: The dealership put a
deflector on the front of
rollers. But stuff still
gets behind it.
3. The automatic tie wont't funtion
properly..
answer: They replaced a sensor
and adjusted it. It lasted
for 6 whole bales.
4. Belt drive clutch woren out. Didn`t
even make 1700 bales.
Answer: Replace half the clutch and
put washers behind the spring
because its too weak.
This is just some of the problems with this thing. Now the warrenty is off and it still dosen`t function right. We`ve phoned the company, but nothing happens. Has anyone else run into this problem. One thing is for sure, their won`t be another Case anything on this farm..
friction and heat..
gets behind it.
properly..
for 6 whole bales.
